Add static ip route in CUCM 6.X
Answered Question
Apr 24th, 2009
does anyone know the command to add a static ip route in CUCM it even supported?
Correct Answer by htluo about 7 years 5 months ago
It's not supported. On CUCM 6.x, you can only specify default gateway. Any routing function was performed by gateway.
Overall Rating: 5 (2 ratings)
balasundaram.k_2 Tue, 10/27/2009 - 04:09
Even I was looking for an answer for the same question. Thank you very much, Michael.
anjali.garg Thu, 12/15/2011 - 06:02
Could someone please confirm if we can add static route on CUCM 7.x series and if yes, what is the command ?
George Thomas Thu, 12/15/2011 - 06:47
Nope not possible in 7 as well.
anjali.garg Thu, 12/15/2011 - 07:15
Hi George,
Thanks for your reply , juts to rule out this option completely, can someone please confirm if it is at all possible with any CUCM  version , just wondering if latest version 8.x supports this?
Thanks in advance,
George Thomas Thu, 12/15/2011 - 07:37
Hi Anjali,
Unfortunately no. The OS for CallManager is pretty much locked down. There are only a couple of commands that can be run from the OS level. Here is the CLI guide for the latest version of CallManager outlining what commands are available.
I am guessing if you have a specific need to route traffic, you probably will have to use route maps on the layer 3 switch.
