04-24-2009 06:09 AM - edited 03-15-2019 05:38 PM
I am having a lot of problems setting up a VWIC BRI in a Cisco 1861 that is connected BRI in Malta. As I am working on this remotely I am having a lot of difficulty getting information to configure this.
The ISDN's will be under MGCP control; however when I carry out a âshow ISDN statusâ the layer 1 is showing as DEACTIVATED. If possible please could someone give me some guidance on the general setup.
Many thanks in advance
Solved! Go to Solution.
04-24-2009 10:43 AM
That is normal, then when an in or out calls happens, the BRI becomes fully activated. Remember to configure "isdn tei-negotiation preserve" under bri interface.
Also, for added stability and ease of troubleshooting, recommend you use the port in h.323 mode.
04-24-2009 10:43 AM
04-24-2009 10:51 AM
Many thanks for this I will try this when I get back to work on Monday.
Also do you know if you set the ISDN up as Basic Net 3?
Cheers
Richard
04-24-2009 10:54 AM
Yes, you do.
04-24-2009 01:52 PM
Many Thanks
04-25-2009 01:11 AM
You're welcome. Please remember to rate useful posts with the scrollbox below.
