Using Aironet 1300 as BRIDGE to Aironet 1522 2.4 GHz Radio
Apr 24th, 2009
Can Aironet 1300 be used to bridge a Workgroup LAN (Building)to the 2.4 GHz Radio (AP)of the Aironet 1522.
What I mean is that if a campus have a Mesh Wireless with Aironet 1522. Can I connect a building LAN to the Mesh Wireless by using Aironet 1300 as a Bridge to the 2.4 GHz Radio Omni Antenna of the Aironet 1522.
Thanks in advance
nalaconsultancy Fri, 04/24/2009 - 08:54
Please, which of the Aironet Bridges can join the mesh. Or Do You have a better solution how to join a LAN Workgroup.
Thanks for the assistance
nalaconsultancy Fri, 04/24/2009 - 10:33
I would like to know if I can deploy a Wireless Mesh with Aironet 1522 without using a Wireless Controller.
Please, if You have more tips about Aironet 1130 and Aironet 1240, I would be most grateful
gamccall Fri, 04/24/2009 - 10:50
The 1500-series access points require wireless controllers. There is no autonomous code option for this access point, and there is no Mesh functionality in IOS.
