ip load sharing, balancing
Apr 24th, 2009
Hi.
Could sombody give me a explanaition of how ip load balancing works.
How it works when two or more routes are installed in the routing table and therefore in the FIB
How it works when ip cef or process switching is enable. Balancing is per packet or per flow by default?
When I enable bgp maximun paths how the balancing works?
Tks
Overall Rating: 1 (1 ratings)
lamav Fri, 04/24/2009 - 08:18
  • Blue, 1500 points or more
Senor, Pedro:
Fijate que hay mucha informacion sobre load balancing y seria mas facil para vos y nosotros si leas un documento de Cisco que cubre las temas que te interesan.
It'll be easier for you to simply read a nice document from Cisco about these issues.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Gracias
Victor
