Warning message
limiting download bandwidth on http
Apr 24th, 2009
how come i m not able to apply a service-policy input when i m using LLQ or WFQ, i get the message :
Flow Fair Queueing feature not supported in input policy
all i want to do is to limit http to 512 kb download and upload
Thanks guys
John Blakley Fri, 04/24/2009 - 07:18
  • Purple, 4500 points or more
If you're trying to shape the traffic from inside out, you can only apply the service policy outbound. You can apply traffic policing policies in or out.
If you want to post your class map, policy map, and interface that you're applying it to, we can take a look.
HTH,
John
I-Routes45 Fri, 04/24/2009 - 07:29
class-map match-all voix
match protocol h323
class-map match-all http
match access-group 102
policy-map priority
class http
police 512000 conform-action transmit exceed-action drop
class voix
priority 256
class class-default
fair-queue
int f0
ip add (the wan ip)
ip nbar protocol-discovery
service-policy output priority
access-list 102 permit tcp any any eq www
access-list 102 permit tcp any any eq 443
it's working on the upload but the download is taking all my bandwitdth.
Thx
John Blakley Fri, 04/24/2009 - 07:40
If you're using nat, you'll need to police the traffic back in based on your public address.
Upload is outbound and download is inbound, so try the following and let me know how it works :)
Try taking fair-queue out of the class-default, and apply the same policy inbound on the public interface.
HTH,
John
I-Routes45 Fri, 04/24/2009 - 08:08
when i removed fair-queue of class-default it let s me put my service-policy input but it does not limit my downloads to the specified rate in policing.
and yes i m using nat
interface FastEthernet0
ip address x.x.x.x x.x.x.x
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
service-policy input priority
John Blakley Fri, 04/24/2009 - 08:29
Try putting it in both directions:
int fa0
You want to shape you traffic going out though. Shape whenever you can.
Try this:
policy-map INBOUND
class http
class voix
priority 256
policy-map OUTBOUND
class http
shape average 512000
class voix
priority 256
int fa0
service-policy input INBOUND
service-policy output OUTBOUND
HTH,
John
I-Routes45 Fri, 04/24/2009 - 08:52
thanks for ur time John but it didn t work, still my downloads starvs all my bandwidth and i cannot use LLQ with input policies.. i tried removing class voix from my policy-map to put service-policy input inbound and it didn t work neither.
John Blakley Fri, 04/24/2009 - 08:56
Another thing you could try is to specifically put your public address in the access-list that's matching the web traffic back in like:
access-list 103 permit tcp any host eq 80
access-list 103 permit tcp any host eq 443
Create a new class-map that matches on this access-list and apply it to the inbound policy map.
It's difficult to control inbound traffic when you're natting.
HTH,
John
Joseph W. Doherty Fri, 04/24/2009 - 09:07
On most router platforms/IOSs, you can not use queuing features within an input CBWFQ policy.
As to it "not working" for downloads, it likely is working, but downstream policing often isn't very effective. For TCP flows, such as HTTP/HTTPS, it requires the sender to detect lost packets and back off it's transmission rate. TCP senders will do this, but the aggregate input traffic often will be much higher than the rate limit. (This because TCP has already openned its send window and only later detects the lost packets.)
You can either try to improve effective downstream rate limiting by decreasing the defined bandwidth (define smaller than the rate you desire) or decrease the Tc.
I-Routes45 Fri, 04/24/2009 - 10:44
i tried everything u said guys but it seems like i can not really control the inboud of the bandwidth even with decreasing the defined bandwidth.
Thank you again
Joseph W. Doherty Fri, 04/24/2009 - 11:25
The only time policing inbound TCP isn't effective is when TCP never needs to get out of slow start. Otherwise, it does work, but again, there's a delay before the sender will back-off and that's often after it already congested your link with a burst.
In practice you often really need to turn down the inbound rate to keep it peaking above your desired rate. What did you actually try? (NB: without adjusting Tc, I've found 1/10 desired rate a starting point. e.g. for 512 try setting 51.)
Again, keep in mind, it's very, very difficult to precisely control inbound traffic on the receiving end on a Cisco router.
Also, another technique is shaping outbound ACKs, but this too tends to be inexact on Cisco routers.
PS:
There are some non-Cisco devices that can better control inbound TCP rates. These too, though, would have trouble with flows that don't need to ramp up out of slow start.
