ASA Failover through WAN Link
Apr 24th, 2009
Actually I have two sites geographically connected by a WAN LInk of 2 Mbps.
On SITE-A I need to install OnE ASA 5520 doing LAN Failover to ASA 5520 on SITE-B.
My question is, Is Posible to do a FAILOVER LAN by a WAN link of the two Mbps??
Or it must have a 100MB of Bandwidth ?
There`s is a specific bandwidht requiritment for Failover over LAN ??
vikram_anumukonda Fri, 04/24/2009 - 07:41
check this link ""
It can be only be a lan based connection
Connect the LAN failover link in one of the following two ways:
•Using a switch, with no other device on the same network segment (broadcast domain or VLAN) as the LAN failover interfaces of the ASA.
•Using a crossover Ethernet cable to connect the appliances directly, without the need for an external switch.
