WAE-512 disk failure
Answered Question
Apr 24th, 2009
A WAAS withe dual disk DISK-SATA2-250GB. One disk failed and I want to replace the drive.
The question is, once I swap the drives will the new drive get rebuilt automatically?
Correct Answer by dstolt about 8 years 1 day ago
Follow the following instructions on cisco.com
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v413/configuration/guide/maint.html#wp1139597
Also remember, the WAE-512 doesn't have hot swap cabability, so you should power off the device after you have performed the "disk disk-name diskxx shutdown" command before pulling the faulty drive.
Hope that helps,
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Fri, 04/24/2009 - 12:50
  • Cisco Employee,
Hope that helps,
Dan
