Dial-peer for internation calls
Apr 24th, 2009
I need to make international calls from my CME.
Can anybody help me with the dial-peer config for this:
dial-peer voice 011 pots
description international dialing
destination-pattern ?
port 0/0/0:23
forward-digits ?
mike-greene Fri, 04/24/2009 - 08:08
  • Bronze, 100 points or more
description International dialing
destination-pattern 9011T
port 0/1/0:23
prefix 011
iptuser55 Fri, 04/24/2009 - 09:03
  • Silver, 250 points or more
Following on you may want to reduce the interdigit timer for calls as if have configured your national calls based upon the actual digit lenght,you can not do this for international calls- I think it is "inter digit timer 4000" - 4 secs????
