UCM7 TFTP cant find .loads file
Apr 24th, 2009
recently uploaded cmterm-7941_7961-sccp.8-4-4.cop.sgn to my cucm7 cluster. I got complete from file upload. Now RTMT trace is saying it cant find the .loads file Any thoughts?
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 04/24/2009 - 07:43
did you uploaded the file to all the TFTP servers???
java
if this helps, please rate
balitewiczp Fri, 04/24/2009 - 07:51
found the problem. I uploaded it through the web gui, which is my pub, but my tftp servers are off subs, and the file is not in the tftp directory.
whats the best way to copy individual files?
Jaime Valencia Fri, 04/24/2009 - 07:56
install the file but log in to the SUBS, just below the install option is the TFTP management
java
balitewiczp Fri, 04/24/2009 - 08:43
got it. downloaded the zip file, and tftp them individually. thanks for your help
