Polycom VTX (analogue) on a UC520
Apr 24th, 2009
There's probably a really easy way to do this, but I'm trying to get a Polycom VTX Analogue conference phone working on my UC520.
The UC520 has an ISDN PRI (E1) on a VIC card and the standard 4 x FXS, 4 x FXO.
I've plugged the Polycom in to one of the FXS ports and get no dial tone, just a 'slow-fast' signal (not sure if that makes sense!!).
Any help would be greatly apprecitated.
Thanks in advance.
paolo bevilacqua Fri, 04/24/2009 - 10:41
  • Hall of Fame,
    Founding Member
Change dialtone configuring "cptone" under voice-port. You should also be able to dial.
campbell.thomps... Fri, 04/24/2009 - 10:45
I have the cptone under voice-port set as follows, but I still don't get a dialtone...
voice-port 0/0/0
cptone GB
timeouts ringing infinity
caller-id enable
paolo bevilacqua Sat, 04/25/2009 - 01:43
  • Hall of Fame,
    Founding Member
Are you trying SCCP controlled ports, is there a DP refering to the same port with application stcapp ?
