VPN with CA
Apr 24th, 2009
I'm implementing a VPN solution with CA certificate using Smart Cards.
I would know If someone has lost his card, How can I bloc it?
Ivan Martinon Fri, 04/24/2009 - 09:01
You would tipically implement CRL checking and make sure that when that happens you revoke the certificate on the lost card.
i.ennassiri Mon, 04/27/2009 - 04:52
I implemented CRL cheking but It doesn't work, bellow the configuration that I made.
crypto ca trustpoint server
revocation-check crl none
enrollment terminal
fqdn test.test.com
subject-name CN=test.test.com,OU=TSWEB, O=Cisco Systems,C=us,St=new ,L=new
keypair my.ca.key
crl configure
policy both
url 1
cache-time 1
no enforcenextupdate
no protocol ldap
no protocol scep
Have you an example of How to do that with a Microsoft CA Server.
Thanks for your help
Ivan Martinon Mon, 04/27/2009 - 07:14
Check your CRL url and see if the server is indeed listening on this port and path, as well your CRL setup is set to none, you need to at least define CRL optional before you need to check that the URL is valid.
