Somebody help!!!
Apr 24th, 2009
I really am getting to the point of frustration!! Any help will be gratefully received...
I have a UC520 with an E1 going in to a VIC. I have succesfully set up and am using 8 x 524SG's on it and want to use a Polycome VTX 1000, a simple analogue conference phone on one of the FXS ports.
When I plug the polycom in, I don't get a dialtone, I just get an engaged tone, with a fast tone, then a slow tone, fast, then slow... You get the picture...
What am I doing wrong? Is there anything special that I need to do?
Any prods in the right direction would be fantastic...
Justin Brenton Sat, 04/25/2009 - 03:47
You have to configured the FXO port to support the Polycom VTX Device.
You will also need supported Dial plan to support the device.
Justin
campbell.thomps... Sat, 04/25/2009 - 05:08
So it would go in to the FXO and not the FXS? I thought the FXS was for analogue devices. How would the dial plan vary?
