04-24-2009 10:22 AM - edited 03-06-2019 05:22 AM
I am planning on stacking 3 3750's. Do all need to have the same IOS? If one has a different IOS is there a command to have the master load his ios onto the switch with the different ios.
04-24-2009 10:29 AM
Switches with the same major version number but with a different minor version number as the stack master are considered partially compatible.
Hope that helps.
04-26-2009 04:01 PM
Working with the Cisco IOS File System, Configuration Files, and Software Images
Hope this helps.
04-27-2009 06:42 AM
You can have the master update the IOS on all the stacked switches.
