BGP: Setting Weight
Apr 24th, 2009
I read Routing TCP/IP Volume II and it was stated there that when route maps are used to set weights, only the AS_PATH can be matched; individual IP addresses cannot be matched with the "match ip address" command.
However, I saw some implementations that used IP address in route-maps to set the weight. I don't know if this is a revised behavior of "weight".
Is this still true or not? Thanks.
John
Giuseppe Larosa Fri, 04/24/2009 - 10:49
  • Hall of Fame,
    Founding Member
Hello John,
there were three options to do this
neigh x.x.x.x weight YYY
that would set to YYY the weight of all routes received by x.x.x.x
neigh x.x.x.x filter-list Z weight YYY
Z is an as path access-list but this has been removed
see
12.1
The weight keyword was removed.
http://www.cisco.com/en/US/docs/ios/iproute/command/reference/irp_bgp3.html#wp1037204
the third option is that of using a route-map.
Inside the route-map as you have noted you can use different match commands not only match AS-path.
the second option now not available according to documentation was limited to AS paths.
Hope to help
Giuseppe
