04-24-2009 12:30 PM - edited 03-21-2019 01:03 AM
I have a new UC520 and have a problem with inter-Vlan communication, I do 3 vlan but, I can´t ping the vlan4 fron vlan 1
And from the laptop I can´t connect to Wvlan (vlan 4)
I attachment the config
thanks
04-24-2009 12:51 PM
You have the wrong default-router in you DHCP scopes
ip dhcp pool data
network 192.168.10.0 255.255.255.0
default-router 192.168.1.1 SHOULD BE 192.168.10.1
dns-server 192.168.1.1 192.168.1.1
ip dhcp pool video
network 192.168.12.0 255.255.255.0
default-router 192.168.1.1 SHOULD BE 192.168.12.1
04-24-2009 02:44 PM
thnaks,
but
I was thinking, tah mabe should be a NAT problem??
some suggestion
04-24-2009 02:53 PM
I am not sure what you mean by a NAT problem. The advice given is correct. Change the default gateway on the pool and this should work.
04-24-2009 03:02 PM
And you dont specify a nat pool of address either. You show pool 1 but there is no pool of address.
04-24-2009 03:14 PM
hi
I change the default route, thanks.
but
I do traceroute into two address
destination 192.168.12.3 source 192.168.10.12
the said that gateway don´t know the subnet 192.168.10.1
04-27-2009 07:55 AM
Do you have other devices in the network? I am not sure how when you traceroute from a 192.168.10.0/24 address you get that the gateway doesn't know about 192.168.10.1.
Can you show a topology? Also, can you show the switchport configuration? How are the devices connecting to the UC500?
