WCS/Location Synchronization Error
Apr 24th, 2009
I have a 4402 that was in demo status in my lab. I then moved it into production. While there were only minor changes such as IP, DNS, hostname, etc. to the 2710, WCS is a fresh install on another machine. When I attempt to synchronize the same 2710 with the new WCS, I get the following error:
A similar element was found in the Server. Please synchronize again to remove any disparities.
I have synchronized several times without success. Any ideas? I'm not open to re-doing the setup on either, so hopefully someone knows of a file on the 2710 that stores the information the error makes reference to and I can just erase it or overwrite it.
Scott
Scott Pickles Mon, 04/27/2009 - 11:38
Figured out a way to resolve the issue without having to blow away my Location Server:
1. Console or SSH into your box
2. Stop the location server by typing
command: /etc/init.d/locserverd stop
3. Go to the directory where the location server stores its location information
command: cd /opt/locserver/db/linux
4. Delete the current database WARNING: YOU WILL LOSE ALL CURRENT LOCATION DATA!!
command: rm -f server-eng.db
5. Reload the appliance
command: reboot
Hope this helps!
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
