problem with replies in Unity mixed environment
Apr 24th, 2009
We are running Unity in a mixed voicemail/unified messaging environment. We are having problems when a VM user leaves a voice message for a UM user, and then the UM user replies to the voice message with a text email. The VM user's mailbox gets the text email reply, but the user has no way to access it.
Is there any way to prevent emails that are not voice messages from getting into a VM only mailbox?
I'm not sure if the text to speach works with VM only mailboxes. If so can TTS be turned on for the VM mailboxes but not for the UM mailboxes? Our UM users do not want the TTS option.
lindborg Fri, 04/24/2009 - 13:11
  • Cisco Employee,
There's no way to prevent the reply - Unity can't reach out and force Exchange to not allow you to reply to a legitimate sender. Some sites do name their VM only accounts with a string like "VOICE MAIL ONLY" in the display name or the like to act as a cue to the desktop user's that replying with text is not a good thing to do - but it's not going to prevent them from doing it again.
You can turn TTS on based on the class of service membership - presumably you're UM and VM users are associated with different COSes already so you can turn on TTS for the VM only users reasonably easily.
