Caller ID
agensler Sun, 04/26/2009 - 06:06
On the IOS gateway side there's no facility to do this. The only translations / adjustments available are for the number only, not the name.
chadlincoln Sun, 04/26/2009 - 17:29
If all you want to do is prepend a number, create a translation pattern that the gateway can call. If the significant digits inbound is four for example, make the translation pattern XXXX. Then for the Calling Search Space, put in a CSS that can call the extensions. For the calling party transform mask, put in 1XXXXXXXXXX which is 1 and the ten digit caller-id. This should prepend the 1 to the caller ID. Do that for gateway one. For gateway two, prepend a 2 and so forth. Make sure that gateway one can only call the translation pattern of XXXX that will translate the caller-id to 1XXXXXXXXXX and make sure that gateway 2 can only call the translation pattern that will transform the caller ID to 2XXXXXXXXXX.
