Upgrade from CCM 6.1 to 7.X
Apr 24th, 2009
Has someone quoted the Call Manager upgrade from 6.1c to 7.X and provide the Part# for 7845-H2 series MCS Serves. The Cisco MLC couldn't find such part#
rob.huffman Fri, 04/24/2009 - 16:00
Hi Abbas,
If you are referring to CUCM 6.1(3), there is no current upgrade path from CUCM 6.1(3) to CUCM 7.0 :(
Release Notes for Cisco Unified Communications Manager Release 6.1(3)
Updated January 6, 2009
**Caution: Be aware that you can not upgrade directly from Unified CM 6.1(3) to Unified CM 7.0
If you look in the supported Upgrade Paths in the first link that I sent you will also see that there are no upgrades shown from 6.1(3) to any of the current 7.x versions (it doesn't jump out but look closely :)
Hope this helps! Sorry man!
