Laurent Aubert Sun, 04/26/2009 - 09:18
  • Cisco Employee,
Hi Gustavo,
Could you please elaborate on what you want to achieve so we will be able to help you
Laurent.
Gustavo Paiva Mon, 04/27/2009 - 04:46
Hi Laurent,
By default, as soon as all available ports have been used for one IP address in the pool, NAT moves to the next available pool address...
I want to do a load balancing between the available IP address, the idea is similar to using "type rotary" but from inside to outside...
Gustavo.
Laurent Aubert Mon, 04/27/2009 - 10:22
  • Cisco Employee,
Hi Gustavo,
Thanks for the update.
It's not supported. You would need to swap your inside and outside to use the rotary feature.
Laurent.
Gustavo Paiva Mon, 04/27/2009 - 10:39
Laurent,
Thanks for your support...
I'll try that...
Gustavo.
