MPLS PE extended
harish.ab
Hello Guys,
IS there any way to get PE routes extended till CE end without loosing Tags , so that overlapping address can be handled
Giuseppe Larosa
Hello Harish,
you can make a shared CE a multi VRF CE.
A multi VRF has a subset of features of a PE node: it has VRFs but it misses MPLS for forwarding.
The link between the PE and the multi VRF CE can be an 802.1Q trunk where each subinterface is associated to a different VRFs.
So you get segregation between the different VRFs but you need to build a routing adjacency on each pe-ce vlan subinterface.
You can use feature navigator to verify if your CE node supports multi VRF CE also called VRF lite.
Hope to help
Giuseppe
