static nat with route-map condition issues
Came upon this a few times recently, wondering if anyone has faced this before…
Has anyone noticed that if you make a static nat rule with a route-map exemption it works on certain routers, and ios versions but not on others??? take this config for instance….
Ip nat pool verizon netmask
Ip nat inside source route-map nat pool verizon overload
Ip nat inside source static route-map servers-nat extendable
route-map nat
match ip address 101
match ip address 102
access-list 101 deny
access-list 101 permit any
access-list 102 deny
access-list 102 permit host any
What is happening is the SERVER at is matching the pool and being natted the pool address instead of its static nat ip.. if I remove the "route-map servers-nat extendable" argument at the end of the static nat, of course it works...
I have the latest IOS on all the routers i'm doing this with...
Any suggestions?
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Sat, 04/25/2009 - 01:22
Hello Joe,
what if you write ACL 101 as:
access-list 101 deny ip
access-list 101 deny ip host any
access-list 101 permit ip any
in this way host is explicitly denied in ACL 101 and shouldn't be natted by the pool.
Hope to help
