Wireless Bridge Solution
I am looking for a wireless Bridge Solution the distance between 2 buildings is 200 Metre approx and the height of the buildings are 24 metres. The desired bandwidth is 11 Mbps and above.
Please help me in finalizing the solution. I am looking for a cheap solution other than 1300, 1400 or 1500 solution.
Regards..
Scott Fella Sat, 04/25/2009 - 05:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You can always use a 1242 in bridge mode with external antennas. You will need a NEMA heated/cooled enclosure for the ap unless that will be mounted indoors, lightning arrestor and LMR cable to extend the antenna if required and antenna mounting hardware. But with most systems, you will need line of site, so hopefully you have this. Antenna wise, you can go with a yagi at both ends.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/prod_qas0900aecd8031c8dc.html
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
