Sub interface using ASA5510
Apr 25th, 2009
I have ASA5510 whose INSIDE interface is connected to a Cisco Cat 2960G switch (L2),Now I have 3 VLAN configured in the Cisco2960G,and a TRUNK port is connected to a ASA5510 Inside interface,that inside interface is configured as a TRUNK,which is automatic (802.1q enabled),in this case Is it possible to have the Inter VLAN communication between these 3 VLANs.If so,how to do it,or is there any requirement of L3 switch or router to have this interVLAN communication?
Please clarify my doubts.
Newzion123.
Jon Marshall Sat, 04/25/2009 - 06:57
Newzion123
Yes the ASA will allow the inter-vlan communication so you don't need an additional L3 switch/router.
First for configuring subinterfaces -
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/intrface.html#wp1044006
then you can either
1) give each subinterface a different security level and setup NAT and access-lists as you would with normal physical interfaces
or
2) give the subinterfaces the same security level and then add this to your config -
ASA(config)# same-security-traffic permit inter-interface
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/intparam.html#wp1039276
Jon
newzion123 Sun, 04/26/2009 - 04:44
Ji Jon,
thanks a lot for extending your support,i will try doing the same and let me inform you.
newzion.
gbenga-olubisi Sat, 04/25/2009 - 23:45
On the ASA5510 inside interface, you need to create subinterface (vlans) and name them (nameif) appropriately. You may assign same security-level to all the subinterfaces; if you do, you will need to config the command "same-security-traffic permit inter-interface" in global configuration. I hope this helps
cannan.ilangova... Sun, 04/26/2009 - 23:13
inter-vlan routing in PIX/ASA is not working as it is intended to...i believe PIX/ASA have an L3 engine which takes care of this routing stuff (as otherwise, it would not have support for RIP and OSPF in v7.2)...but for some reasons, i am not able to get the box do it...any help from the experts would be greatly appreciated...
i have the following topology
FW1(PIX)---FW2(PIX)
CoreSw1---CoreSw2
AccessSwitch
PC1 PC2
the relevant configurations from my PIX is below...PIX1 and PIX2 are in Failover Cluster Mode...no question of NAT as i have disabled it using the Global configuration command "no nat-control"
interface e1
nameif TRUNK
security-level 100
no ip address
interface e1.10
vlan 10
nameif RMS-SD
security-level 100
ip address 10.116.205.130 255.255.255.128
interface e1.80
vlan 80
nameif RMS-DS
security-level 100
ip address 10.116.217.1 255.255.255.0
access-list inbound_in extended permit ip any any
access-list outbound_out extended permit ip any any
access-group inbound_in in RMS-SD
access-group inbound_in in RMS-DS
access-group outbound_out out RMS-SD
access-group outbound_out out RMS-DS
access-group inbound_in in TRUNK
access-group outbound_out out TRUNK
same-security-level permit inter-interface-traffic
same-security-level permit intra-interface-traffic
PC1 Gateway (PIX) : 10.116.205.130
PC1 interface IP : 10.116.205.132
PC2 Gateway (PIX) : 10.116.217.1
PC2 interface IP : 10.116.217.3
I am able to PING the Gateway(PIX) of PC1 from PC1 and the Gateway(PIX) of PC2 from PC2. But I am not able to reach/ping PC2 from PC1 and vice-versa.
cannan.ilangova... Mon, 04/27/2009 - 00:48
i was wrong...it indeed was working...i was attempting to ping the gateway IP of PC1 from PC2 and vice-versa which is NOT working though..
but my attempt to ping PC1 from PC2 and vice-vera was successful...
thanks to all experts for their suggestions!!!
