How to configure Router to Router serial connection?
Answered Question
Apr 25th, 2009
I have two 2610 routers and they each have a WIC-1T card. I connect them through a CAB-6060 Back-to-Back DTE-DCE cable. "Show inter s0/0" shows the connection is up/up. However can't ping each end... I also tried to put "encapsulation ppp" but still no go... How should I configure it? Thanks!
Correct Answer by davy.timmermans about 7 years 10 months ago
did you configure a clock rate at the DCE side?
for example:
clock rate 64000
to check if the side is DTE/DCE:
show controllers serial ser0/0
you'll see in the text or DTE or DCE
Overall Rating: 5 (1 ratings)
Correct Answer
davy.timmermans Sat, 04/25/2009 - 12:21
for example:
clock rate 64000
david-lima Sat, 04/25/2009 - 19:37
Hi, also check if "ip routing" command is enabled in both routers.
Best regards
David
