call Redundancy between two PRI ???
Apr 25th, 2009
hi guys,
i have CCM 6.1 Cluster and two PRI lines terminating on two different routers, and i have to configure redundancy between both PRI Lines ???? how to do that ???
is it possible to configure that one call goes to PSTN via one PRI and second call to PSTN via second PRI ????
if yes how we can configure it ????
Jaime Valencia Sat, 04/25/2009 - 19:13
if MCGP configure the mgcp redundant host command
if H323 configure dial-peers with higher preference
for outgoing calls configure the route group with circular as Distribution Algorithm
java
if this helps, please rate
Ayodeji Okanlawon Sat, 04/25/2009 - 21:44
Java,
I believe MGCP redundant host command is for CCM redundancy.
so with MGCP and H323 he has to use Route groups. As java said assign the PRI end points to the same route group and use circular algorithm. CCM will automatically load balance between them.
