Example VPN config help
Apr 25th, 2009
Hello, I hope someone can put me in the right direction here.
I will be configuring a Cisco 2621 router that will need to have a VPN connection to a Cisco ASA firewall. I was wondering if anyone has a simple config I could use based on the following settings, I am trying this in a lab first so the outside ports are in a hib at the moment:
ASA:
LAN - 192.168.200.0/24
Outside IP - 1.1.1.1 (example IP)
AES-256/SHA
DH-Group 5
Pre-shared Key - cisco
Router:
LAN - 10.10.10.0/24
Outside IP - 2.2.2.2
Let me know if I have missed anything.
jamesgonzo Sun, 04/26/2009 - 02:14
Thanks for spending the time to answer my post.
It will be a static to staic site-to-site VPN not dynamic.
In my lab I think I will have to give both peer IP's (outside ports into hub) an address in the same subnet so they can commuicate?
Not really - all you need is a x-over cable and some default static routes.
e.g ASA:-
Outside Interface
IP address 1.1.1.1 255.255.255.0
route outside 0.0.0.0 0.0.0.0 1.1.1.1
E.G Router:-
int eth 0/0 or fa 0/0
ip address 2.2.2.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 eth 0/0 or fa 0/0
The above instructs the device to pass default traffic out the respective interfaces and "arp" for the mac using the specific IP or interface - since they are on a hub or x-over the remote side will respond.
HTH>
jamesgonzo Sun, 04/26/2009 - 02:32
Thanks.
Sorry for the silly question but if 1.1.1.1 and 2.2.2.2 go into a hub how will they ping each other as they are on different subnets?
Not a silly question if you do not know - but you are missing some of the basic priciples.
Even though it's not proper english - you should never answer a question with a question, but this time it's fitting to do so...so let me ask you:-
What is a broadcast domain?
What is ARP?
Knowing the concepts/operation of the above will answer your question.
HTH>
