Cannot make outbound call through ISDN30
Apr 26th, 2009
Hello all,
I've a problem in outbound call with analog devices.
We use 2821 as SRST on branch office and connect to PSTN with ISDN30.
All of my VOIP & analog devices can reach from outside with their DID number.
But I can't make a outgoing call with the fax machine and analog phones.
All the VOIP phones can call outside with PSTN line.
Please see the attach for logical diagram.
What should I need to add in configuration to send out the fax using PSTN line.
Thank you for your help.
here's the srst router's config.
no ip domain lookup
isdn switch-type primary-5ess
voice-card 0
dspfarm
dsp services dspfarm
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 6562
rule 1 /6562/ //
voice translation-profile in
translate called 6562
crypto pki certificate chain TP-self-signed-3393231679
certificate self-signed 01 nvram:IOS-Self-Sig#3903.cer
controller E1 0/2/0
pri-group timeslots 1-31
controller E1 0/2/1
interface GigabitEthernet0/0
description Local
ip address 10.54.120.2 255.255.255.0
duplex full
speed 100
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.54.120.2
interface GigabitEthernet0/1
description to RemoteOffice
ip address 192.168.54.2 255.255.255.248
duplex full
speed 10
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
router eigrp 1
network 10.54.120.0 0.0.0.255
network 192.168.54.0 0.0.0.3
no auto-summary
ip route 0.0.0.0 0.0.0.0 10.54.120.1
control-plane
voice-port 0/0/0
timeouts ringing infinity
description Fax 2401
station-id number 2401
caller-id enable
voice-port 0/0/1
description Fax 2428
station-id number 2428
caller-id enable
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0:15
translation-profile incoming in
cptone SG
bearer-cap Speech
sccp local GigabitEthernet0/0
sccp ccm 10.40.120.12 identifier 1
sccp ccm 10.40.120.11 identifier 2
sccp ip precedence 3
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CFB002497FE1EA0
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
associate application SCCP
shutdown
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 1001 pots
preference 2
destination-pattern 9[3-9].......$
port 0/2/0:15
forward-digits 8
dial-peer voice 1002 pots
preference 2
destination-pattern 9800.......$
port 0/2/0:15
forward-digits 10
dial-peer voice 1003 pots
preference 2
destination-pattern 91800.......$
port 0/2/0:15
forward-digits 11
dial-peer voice 1004 pots
preference 2
destination-pattern 91900.......$
port 0/2/0:15
forward-digits 11
dial-peer voice 1005 pots
preference 2
destination-pattern 999[3,5,9]
port 0/2/0:15
forward-digits 3
dial-peer voice 1006 pots
preference 2
destination-pattern 90T
port 0/2/0:15
prefix 0
dial-peer voice 1007 voip
preference 3
destination-pattern ....
voice-class codec 1
session target ipv4:10.40.120.12
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1008 voip
preference 4
voice-class codec 1
session target ipv4:10.40.120.11
no vad
dial-peer voice 1009 pots
preference 2
destination-pattern 2401
port 0/0/0
dial-peer voice 1010 pots
preference 2
destination-pattern 2428
port 0/0/1
call-manager-fallback
secondary-dialtone 9
max-conferences 16 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 10.54.120.2 port 2000
max-ephones 50
max-dn 80
keepalive 60
moh music-on-hold.au
multicast moh 239.1.1.2 port 16384
time-zone 43
CHRIS CHARLEBOIS Mon, 04/27/2009 - 12:19
  • Silver, 250 points or more
First, I recommend turning on the ISDN Q931 debug during an outbound call. That debug setting provide a load of useful information when dealing with ISDN issues.
I don't personally use the 'forward-digits' command, but I'm not sure why it wouldn't work. I use the prefix command to put back what the PSTN is expecting. For example, If I have a POTS dial-peer with a destination pattern of 91800........., I would include a command of 'prefix 1800' to put back the digits that were stripped when matching the pattern.
So, get the debug and post it back here, or try using prefix instead of forward digits, and let us know how it works.
