How to collect the attempts of calls after translation rule applied?
Apr 26th, 2009
We applied the following translation rules on our voice gateways in order to block malicious incoming calls.
"voice translation-profile call_block
translate incoming 1
voice translation-rule 1
rule 1 reject /##########/
rule 2 reject /##########/
dial-peer voice 1 voip
call-block translation-profile call_block"
My questions is - Is there any way to collect the number of those calls hitting our voicegateways?
By the way, the version of gateways is 12.4 (13D)
Jessica
Paolo Bevilacqua Mon, 04/27/2009 - 01:41
You can route them to a service that announces not to call anymore, using CDR you would also record calling number and time of call.
Note however that usually, after a while malicious callers learn how to hide calling number, thing against which you've no remedy.
learner2008 Mon, 04/27/2009 - 06:58
Could you please provide me with further information about re-routing to a service number? Can it be implemented on gateways or CCM?
Since I have asked a couple Cisco TAC and was told it is impossible to re-route calls.
Paolo Bevilacqua Mon, 04/27/2009 - 08:20
You do not re-route. You route calls coming from certain numbers, to annunciator, route point or so. This is done adding specialized pots DP with an answer-address, and translating the called number to the service number.
learner2008 Mon, 04/27/2009 - 08:32
Is there any documentation regarding to routing certain calls to announciator? Does it have to be done on CCM or both CCM and Gateways?
Thanks for your help.
