SOHO91 NAT not working.
I am trying to Nat. I am not getting translations. Its connected to Cable modem and I and ping www.yahoo.com and WAN IP addresses from IOS. Why is NAT not working? DHCP is working and DNS is correct getting it from Cable modem.
Router Model : SOHO91
IOS Image Name : soho91-k9oy6-mz.123-2.XC2.bin
IOS Version : 12.3(2)XC2
Number of Telnet connection(s) : 1
Router Up Time : 19 minutes
Building configuration...
Current configuration : 1198 bytes
version 12.3
no service pad
hostname Petaluma
no logging buffered
enable secret 5 <removed>
enable password <removed>
username CRWS_Bijoy privilege 15 password 0 <removed>
username CRWS_Jaidil privilege 15 password 0 <removed>
no aaa new-model
ip subnet-zero
no ip routing
ip name-server 68.87.76.178
ip name-server 68.87.78.130
ip dhcp excluded-address 192.168.0.1
ip dhcp pool CLIENT
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
lease 0 2
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip route-cache
no cdp enable
hold-queue 32 in
interface Ethernet1
ip address dhcp client-id Ethernet1
ip nat outside
no ip route-cache
duplex auto
no cdp enable
ip nat inside source list 102 interface Ethernet1 overload
ip classless
ip http server
no ip http secure-server
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
no cdp run
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
password <removed>
login local
length 0
scheduler max-task-time 5000
end
Petaluma#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Ethernet1
Inside interfaces:
Ethernet0
Hits: 0 Misses: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 102 interface Ethernet1 refcount 0
Petaluma#sh ip nat translations
Petaluma#
mahmoodmkl Sun, 04/26/2009 - 21:37
  • Gold, 750 points or more
ip routing is disabled.enable it and try.
router(config)#ip routing
Mahmood
Marwan ALshawi Sun, 04/26/2009 - 23:34
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
why it is disabled is it by default in the router ?
