We have having frequent disconnection issues with Cisco 2924 Management IP...
If any one have information if this is a BUG!!
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 17:35 by ayounes
Image text-base: 0x00003000, data-base: 0x00301F3C
ROM: Bootstrap program is C2900XL boot loader
DIGsgMUSclewm21 uptime is 29 weeks, 1 day, 8 hours, 40 minutes
System restarted at 22:10:26 UTC Sat Oct 4 2008
System image file is "flash:c2900XL-c3h2s-mz-120.5.2-XU.bin"
cisco WS-C2924C-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
Processor board ID , with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Motherboard assembly number: 73-3381-08
Power supply part number: 34-0834-01
Motherboard serial number:
Power supply serial number:
Model revision number: A0
Motherboard revision number: C0
Model number: WS-C2924C-XL-EN
System serial number:
Configuration register is 0xF
