RME baseline template
Apr 26th, 2009
I use LMS 2.6 with RME 4.0.5.
I would like to use the baseline template to do a conditionnal deloyement of config like this:
if switchport mode access and not switchport access vlan then apply switchport port-security.
Is it possible to do it with LMS 2.6 or any other version ?
Joe Clarke Mon, 04/27/2009 - 09:19
This is only possible in RME 4.1 or higher (LMS 3.0 or higher).
MathieuJM_2 Mon, 04/27/2009 - 09:26
There is no way to use LMS in some woraround way to have those kind of functionnality ?
Joe Clarke Mon, 04/27/2009 - 09:28
No, not this conditional deployment. Th only workaround is to do the analysis in a separate tool (i.e. use Netshow to get a list of ports). Then you can use Config Editor or Netconfig to deploy the changes you want.
