Apr 27th, 2009
i have set up MTP resources on IOS router to be used with Call Manager for alaw to ulaw conversion.
I configured three MTPs on the gateway, one for alaw, one for ulaw and one for clear and added all three of them to media resource list on Call Manager:
dspfarm profile 1
codec g711alaw
maximum sessions software 100
dspfarm profile 2
codec g711ulaw
dspfarm profile 3
codec pass-through
The SIP trunk between Call Manager and the gateway has MTP required checked and g711alaw codec as preffered codec, since most calls work with alaw towards the provider.
However, i want some calls to be ulaw, so i have set ulaw on specific dial-peers toward Call Manager.
The problem is that the MTP doesnt convert between alaw and ulaw as it should, so the only way i can make this work is if i use transcoding directly on the gateway.
Could the problem be with 3 different MTPs or with g711alaw preffered setting on the trunk?
Debug ccsip messages gives me "SIP 501 not implemented error" , q.850 65 cause code. If i use transcoding on gateway itself, it works, otherwise nothing is sent to Call Manager.
This is what i get, when i use transcoding (this is on call, but has 2 xcode and 2 mtp sessions):
19 19 xcode sendrecv g711u 18704 2000
19 20 xcode sendrecv g711a 18028 2000
16969882 16875147 mtp sendrecv g711u 17612 31540
16969882 16875146 mtp sendrecv g711u 19136 19424
( is the gateway, is endpoint)
Best regards,
Overall Rating: 5 (1 ratings)
chadlincoln Mon, 04/27/2009 - 03:54
If you are going from one codec to another, you are correct in thinking you'd need a transcoder instead of a MTP.
markotisler Mon, 04/27/2009 - 03:55
But shouldnt MTP take care of alaw to ulaw conversion also? As i recall this souldnt need a transcoder...
