04-27-2009 12:51 AM
I would like to know why ACE doesn't export SSL key in unencryped format?
Thanks in advance.
Sum
04-27-2009 06:45 AM
switch/Admin# crypto export CSMS-key-clear.pem terminal
-----BEGIN RSA PRIVATE KEY-----
MIICXQIBAAKBgQDIRNy11/IpUoEn4yESIcc40YUvUChFnTokDop8vbYLA5hgWc2g
For an encrypted key :
switch/Admin# crypto export key.pem
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,C88A325521B26CF4
Cp2fFFdYKUpfl8Je7kcpliCfLQ9HYreLqsDSpzVpZx1ooYaH7+RCnDFh+Xh1ZL/t
We do support SSL key export.
However, we do not un-encrypt the key.
This can be done w/ "openssl rsa -in
Gilles.
04-27-2009 06:55 AM
Hi giles,
Thanks for the update. Yes that correct what you updated in the notes but what i want is why is it ACE doesn't export SSL key in unencryped if it was imported in encrypted format?? and Is it possible to export all keys in unencrypted format in the future, regardless in which format those were imported?
Thanks in advance.
Sum.
