3845 connect another 2 routers over dark fibre
Apr 27th, 2009
HI , I am planning to link up 2 3845 routers with 1 3845 router at my data center. Will the data throughput affected?
IS there any site have similar setup for reference?
Paolo Bevilacqua Mon, 04/27/2009 - 01:43
Just do not expect to be able to use a gigabit link at wire speed. Use L3 switches for that.
Joseph W. Doherty Mon, 04/27/2009 - 03:30
Often the data throughput is more dependent on the amount of traffic being forwarded more so than the number of links. In other words, a 3845 has a certain level of data forwarding that it can support, doesn't matter as much number of peer/connecting routers, more so traffic volume that will be passed though it. Of course, everything else being equal, more links/peers might increase traffic load.
A 3845 is recommended for T3s (single one), but they also seem to be able to forward up to about 100 Mbps (duplex).
