7604 CiscoView 6.1.7
Apr 27th, 2009
I'm using CiscoView 6.1.7 on LMS 3.0.1.
When I try to use CiscoView on a 7604 I receive a router partial layout with four level, first with a yellow text "Unsupported Card", second with a WS-X6724-SFP and the correct layout, the third e fourth card are empty.
The show version output is :
RT-XT1#show version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 10-Oct-07 08:10 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRC3, RELEASE SOFTWARE (fc1)
RT-XT1 uptime is 6 weeks, 3 days, 1 hour, 21 minutes
Uptime for this control processor is 6 weeks, 3 days, 1 hour, 20 minutes
Time since RT-XT1 switched to active is 6 weeks, 3 days, 1 hour, 21 minutes
System returned to ROM by reload (SP by reload)
System restarted at 09:37:25 CET Fri Mar 13 2009
System image file is "disk1:c7600rsp72043-advipservicesk9-mz.122-33.SRB2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco CISCO7604 (M8500) processor (revision 2.0) with 851968K/65536K bytes of memory.
Processor board ID FOX1216GNMX
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
4 Virtual Ethernet interfaces
26 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Any suggestion ?
thank's
Claudio
Joe Clarke Mon, 04/27/2009 - 09:27
Please post the output of show inventory from this router. What versions of the following CiscoView packages do you have loaded:
CLIParser
CVGenericPackage
Cat6000IOS
Entity
NGMARShare
Routershare
SwitchAddlets
sys1.vtamlist Mon, 04/27/2009 - 23:09
Thank's !
I've attached output of sh inv command...
This is the version packages automatically added to CiscoView 6.1.7 by LMS 3.0.1
CLIParser 1.4
CVGenericPackage not present
Cat6000IOS 9.0
Entity 1.7
NGMARShare 1.1
Routershare not present
SwitchAddlets not present
Thank's
Claudio
Joe Clarke Tue, 04/28/2009 - 08:31
You need to upgrade your CiscoView packages. Go to Common Services > Software Center > Device Update, check CiscoView, and download and install all available package updates.
sys1.vtamlist Tue, 04/28/2009 - 22:34
Thank's !
It's work correctly !
I started update operation 2 weeks ago but I haven't check log of the operation...
Update didn't work due a credential error...
I'm sorry for your time !
Claudio
