Apr 27th, 2009
Hi all, is IGMP snooping enabled by default on cisco switches, also do they use IGMP proxy function?
If so how do I turn these functions off / on
Overall Rating: 5 (1 ratings)
Harold Ritter Mon, 04/27/2009 - 09:56
IGMP snooping is enabled by default. IGMP proxy is not. To disable IGMP snooping:
no ip igmp snooping
(per vlan)
no ip igmp snooping vlan xxx
carl_townshend Tue, 04/28/2009 - 00:26
should this be turned off then? or should I leave it on? How can I check the group to port assignments ?
also what benefit is IGMP snooping and IGMP proxy ?
Giuseppe Larosa Tue, 04/28/2009 - 03:44
Hello Carl,
as we discussed in another thread it is a question of implementation:
on switches supporting IGMP snooping in HW using an ASIC it is good to have it enabled.
Hope to help
aciscolook Wed, 05/13/2009 - 15:29
what if i use igmp snooping to constrain multicast traffic but don't have a router in the mix. Will this work?
Again, just one (maybe two) switch with IGMP snooping and no router.
