Warning message
CISCO 1760 Serial Number
Apr 27th, 2009
We are having cisco 1760 routers we need
serial numbers of those routers.
we tried sh version, sh inventory, sh diag it shows serial no. of processor bord .
is ther is any another command by which we can get serial no. ?
we are using 12.4 advance security ios
regards
pushpak
Overall Rating: 5 (2 ratings)
paolo bevilacqua Mon, 04/27/2009 - 04:34
  • Hall of Fame,
    Founding Member
No, there is no other command.
Richard Burts Mon, 04/27/2009 - 09:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
pushpak
Paolo has given the correct answer for your question. Note that this function is platform dependent. There are some platforms, especially the ISR routers, in which the show inventory command will provide the serial number for the router. I believe that there may be some platforms in which the serial number may appear in other show commands. But for the 1700 router the only way to find the serial number is to physically look at the chassis.
Rick
pushpak.lele Mon, 04/27/2009 - 21:16
thanks for the information
is there is no other way to get serial no. remotely.
regards
pushpak
Richard Burts Tue, 04/28/2009 - 08:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
pushpak
There is no way to get the router serial number remotely for the 1760 routers.
Rick
Sushil Kumar Katre Thu, 04/30/2009 - 01:55
  • Gold, 750 points or more
Hi Pushpak,
Paolo and Rob are bang on target (+5). and I going to reiterate the same
There is no way to get the serial nnumber of 1700 series router remotely.
-> Sushil
