Global timeouts
Apr 27th, 2009
Hello to all.
The connection timeouts on ASA firewall are the default ones, so for Idle connection is 1 hour.
My question is : the SSH Idle connection between to hosts on different interfaces of ASA will be disconnect after 1 hour or not? Or after 10 min , time of half open connection?
Best regards
Try this example - I've included a network object group so that you can see how to implement using that as well:
access-list EX-CONN remark Custom timeout policy for Users to not timeout to Exchange
access-list EX-CONN extended permit ip object-group ExchangeServers
class-map EX-CONN
description Custom timeout policy for Certain users to Exchange
match access-list EX-CONN
policy-map global_policy
class inspection_default
inspect dns maximum-length 2048
class EX-CONN
set connection timeout tcp 9:00:00
