Compatibility between WAP200 & HGA7S
Apr 27th, 2009
Is it possible to fit an HGA7S high gain antenna to an WAP200 access point and if so, will the range be extended?
mcopilet1 Mon, 04/27/2009 - 13:59
Hi Rob,
That's what I think too, with the same connection it should work.
Interesting about the end-of-life announcement for the HGA7S, one wonders why there is no replacement for it, either it was too good and the use of it broke the regulations, or it was so terrible that they discontinued it
