DHCP server across VLAN's
Answered Question
Apr 27th, 2009
  • Silver, 250 points or more
I have configured muliple vlan's in my l3 switch & vlan inter-routing is enabled. I have a Linux DHCP server which is sitting in Vlan2 & it has to serve the ip addresses to vlan3 & vlan4 which are falling in different subnet . So having a "ip helper-address <linux dhcp server ip>" command added in vlan3 & vlan4 interface will serve this or do i need to include any other command?
Correct Answer by John Blakley about 8 years 2 months ago
That should be all you need.
int vlan 3
ip addres 192.168.15.1 255.255.255.0
ip helper-address 192.168.1.50
int vlan 4
ip address 192.168.20.1 255.255.255.0
int vlan 2
Your routing table will show 192.168.1.0 as a connected route to vlan 2 and will route it correctly.
HTH,
John
Correct Answer by thotsaphon about 8 years 2 months ago
Anand,
An ip helper-address command is enough. As long as you correctly configure the server(pools).
Toshi
Overall Rating: 3 (2 ratings)
Correct Answer
thotsaphon Mon, 04/27/2009 - 05:53
  • Gold, 750 points or more
Anand,
Toshi
Correct Answer
John Blakley Mon, 04/27/2009 - 05:54
  • Purple, 4500 points or more
int vlan 3
int vlan 4
int vlan 2
HTH,
John
Anand Narayana Mon, 04/27/2009 - 06:01
Thanks a lot Toshi & John. I will be testing in the next 2 hrs & will rate for sure :-)
