SRST and UCCCX
Answered Question
Apr 27th, 2009
We have a CUCM Business edition ver 7.0
and srst ver 7 voice gateway with UCCX ver 5.0
In event of Business edition failing, we have got SRST configured on the Gateway.
Is there a way that I can configure the voice gateway to be able to use the UCCX.
Correct Answer by Chris Deren about 8 years 2 months ago
Unfortunately it's not that simple as UCCX does not include H323 nor SIP protocols, so dial-peers can not be used.
UCCX uses JTAPI for call control for which you need either CallManager or CallManager Express.
HTH,
Chris
Correct Answer by PETER NEGUS about 8 years 2 months ago
Personally, I would consider using the B-ACD TCL script on the gateway. That way you can have resilience against UCCX failure as well (or even get rid of it completely :-)
Overall Rating: 5 (2 ratings)
chadlincoln Mon, 04/27/2009 - 06:48
  • Bronze, 100 points or more
There is no way to do that since you can't have JTAPI integration with SRST. I would make sure you have the alias command under call-manager-fallback and have inbound numbers at least his an extension during a failover.
Chris Deren Mon, 04/27/2009 - 12:00
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You could run SRST as CME, but UCCX can be integrated with one or the other. So as an alternative you can implement second UCCX server and integrate it with CME (SRST).
Alternatively you can configure BACD on the router as a backup when site is in CME (SRST) mode.
Chris
pcromwell Mon, 04/27/2009 - 21:13
thanks for the responses, actually all I need to do is run a script on uccx that is for out of hours, we don't have any agents.
SO I am guessing I just need a dial peer
poinitng to the UCCX server?
Correct Answer
PETER NEGUS Tue, 04/28/2009 - 04:47
Correct Answer
Chris Deren Tue, 04/28/2009 - 04:48
  • Hall of Fame,
HTH,
Chris
