FAX pstn-wan-pstn error
Answered Question
Apr 27th, 2009
  • Events Top Contributors,
    External, 2014
Hi all!
Im have this case:
PSTN -> (e1) -> router1 -> WAN -> router2 -> e1 -> PSTN
im using this for cost purpose, i redirect a fax call to a "external voice-mail fax".
I tried to create a dial-peer voip gateway to gateway but didnt work.
lets me show the config of router1.
voice class codec 2
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 5
voice translation-rule 6925
rule 1 /^6925/ /028452546/
voice translation-profile FAX-CT
translate called 6925
dial-peer voice 69251 voip
translation-profile outgoing FAX-CT
destination-pattern 6925
voice-class codec 2
voice-class h323 1
session target ipv4:10.111.8.7
dtmf-relay h245-alphanumeric
Ip of router2 is 10.111.8.7
When i call to 6925, i hear the fax ringback ( because 028452546 answer the call ) but error occurs.
I see the call (on #show call active voice brief) that does on g711ulaw
Correct Answer by Nicholas Matthews about 8 years 1 month ago
Add this to your configuration:
voice service voip
modem passthrough nse codec g711ulaw
I think this will help.
-nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Mon, 04/27/2009 - 11:49
  • Red, 2250 points or more
voice service voip
-nick
Guilherme Henri... Tue, 04/28/2009 - 10:50
    External, 2014
Thanks for your help, i will apply and test.
if works, i will rate your post.
