2821 ISR - ssh2
Apr 27th, 2009
I would like to know if the following IOS version only supports ssh v.1.99 or if it supports true ssh v.2.
The IOS is 12.4(13r)T
Our Nessus scans continue to kick back the vulnerability due to the 1.99 option which allows version 1 ssh connections. I believe we may have purchased the incorrect IOS image for the router.
If not, how do I allow the router to only accept version 2 connections?
ip ssh version 2.0 at the CLI continues to report back as v1.99
thanks,
Jim
Richard Burts Mon, 04/27/2009 - 09:00
Jim
Release 12.4T should support SSH version 2, assuming that it supports SSH.
I have seen a couple of situations where IOS seems to have gotten confused and was not enabling version 2 as desired. If that is your case I would suggest that you remove the version 2 specification (no ip ssh version 2), then regenerate the RSA keys used for SSH (perhaps zeroize the key and then regenerate it is you want to be very thorough), then enable version 2 with ip ssh version 2. I have seen situations where doing this did resolve the issue. I do not know if that is your issue but it would be worth trying.
Rick
cdcjim2877 Mon, 04/27/2009 - 10:07
Once I stepped through the your comments on the router, version 2 (only, not v1.99) now shows.
I have also tested by trying to connect via SSH 1 client and am not able to connect.
thanks,
Jim
Richard Burts Mon, 04/27/2009 - 10:19
Jim
I am glad that my suggestions were able to help you to resolve your issue.
Rick
Edison Ortiz Mon, 04/27/2009 - 09:00
v1.99 is the default SSH output when running v1 and v2. I've covered the outputs you get for each version on this thread http://tinyurl.com/c7uydc
Can you post the output from typing show version?
__
Edison.
cdcjim2877 Mon, 04/27/2009 - 09:48
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:09 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
TT_HQ_2821_CR_1 uptime is 1 week, 2 days, 3 hours, 39 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-3i.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1221A2MM
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
