To configure a QoS for the attached topolgy
Apr 27th, 2009
Dear friends,
I have to configure QoS for the attached topology with the following requirements, can any one please help me to do the same.
The minimum requirements are that 4 simultaneous VoIP calls need to be supported across the backbone, as well as a dedicated 10MBs of http traffic. Of the remainder of the bandwidth ftp traffic should be given a high priority. Make sure routing protocols are given a suitable priority level.
Thanks and expecting replies
CHRIS CHARLEBOIS Mon, 04/27/2009 - 07:24
  • Silver, 250 points or more
Three things I want to point out...
1) You cannot dedicate 10 MBs for HTTP on a 1.54 Mbs link.
2) You have not described where the call control (IP PBX) is located.
3) There is a line between asking for help and asking for someone to do your job. This is a line that you appear to have crossed. I recommend you come up with a sample config of what you think it should look like and post it here for comment and advice.
0iyaaaaaa Mon, 04/27/2009 - 07:56
First I would like to thank for the reply message.
Really I didn't mean to do my job, I haven't got any idea how to configure this topology, its my university assignment work. so if possible please guide me to finish this topology.
Jaime Valencia Mon, 04/27/2009 - 08:31
  • Cisco Employee,
  • Hall of Fame,
    2011
you can start by reading QoS guides
Quality of Service (QoS)
White Papers
http://www.cisco.com/en/US/products/ps6558/prod_white_papers_list.html
If this is a University assignment then i must assume this is something you need to learn, so there is no good in having someone hand out a config based on what YOU were asked to do.
java
if this helps, please rate
CHRIS CHARLEBOIS Mon, 04/27/2009 - 08:39
Here are some questions that you'll need to answer, to get started.
What does the HTTP requirement mean? It is not possible to get 10 Megabytes per second on a 1.544 Megabit per second line.
What voice codec will be used on the IP Phones? This will determine how much bandwidth you need to allocate.
Next, read the following link:
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/12_4t/qos_12_4t_book.html
It's all in there. Unfortunately, it's a big topic, so there is a lot there.
0iyaaaaaa Mon, 04/27/2009 - 09:13
Thanks and I've to ask my supervisor why about your questions and I'll let you know.
0iyaaaaaa Tue, 04/28/2009 - 07:28
The Http traffic was a typo, so no need of it and we can fix the call manager where ever we need. This is what i got from supervisor.
It will be helpful if you guide me thanks
CHRIS CHARLEBOIS Wed, 04/29/2009 - 05:15
Considering this is your assignment, I believe it's up to you to read through the documentation that has already been linked and put together a solution for yourself. The people here will typically be happy to review whatever you put together, or help if you get stuck on a particular topic or question.
0iyaaaaaa Wed, 04/29/2009 - 05:33
Thanks and I'll let you know if I got struggling in any particular topic
