04-27-2009 08:05 AM - edited 03-04-2019 04:32 AM
Can anybody tell me router forward packet or frame. when we connect two routers using leased line and we used PPP or HDLC protocol.It means HDLC and PPP are DLL protocol. when DLL comes means there is frame.Am I right. waiting for experts reply...
Solved! Go to Solution.
04-30-2009 04:25 AM
At DLL, serial might be assumed point-to-point while Ethernet can be assumed multipoint. With p-2-p, there's no need to resolve physical destination, but with multipoint there is. (NB: ARP isn't limited to just Ethernet, see http://en.wikipedia.org/wiki/Address_Resolution_Protocol)
04-30-2009 04:56 AM
Normally no. IP hosts maintain ARP caches. Router will ARP once for destination, and use cached results until ARP cache times out. On Cisco routers, "show ip arp" (I think that's the command) will show the ARP cache.
04-27-2009 08:15 AM
What DLL means ?
Usually, frame is a L2 term, packet a L3 term. Often the two terms are used indifferently.
04-27-2009 08:17 AM
Hello Irfan,
using the layered OSI model a router works at layer3 but when it sends out a L3 PDU like an ipv4 packet it has to encapsulate it inside the correct L2 frame suitable for the outgoing interface:
so if the outgoing interface is a serial interface using PPP the ipv4 packet is inserted inside a PPP frame that has a protocol type in the header that tells it is carrying an ipv4 packet inside.
the frame is prepared and it is sent out as a sequence of 0 and 1 on the wire (OSI layer 1 line code)
if the encapsulation is Cisco HLDC the ipv4 frame is inserted into an HDLC frame and so on.
Hope to help
Giuseppe
04-27-2009 08:27 AM
In short you means to say it sends frame...for frame it requires mac.. ok will it send ARP request for each packet or once for each communication.And if we are using point to point link to connect routers it is necessary to send ARP.
waiting for reply...
04-27-2009 08:31 AM
Do not jump to conclusions.
Frame does not mean necessarily MAC.
Serial protocols like HDLC, PPP, have no MAC address as you know it, in fact have a 4 bits address always set to broadcast.
There is no ARP on serial links.
04-27-2009 08:39 AM
And if we are using interface other than serail then what it does?
04-27-2009 08:44 AM
It depends by the specific of the interface.
04-27-2009 08:44 AM
Router forwards L3 packets (OSI network layer). Router encapsulates the L3 packets into L2 frames (OSI data link layer).
04-29-2009 07:36 AM
Will it send ARP on fast ethernet?
04-29-2009 04:16 PM
"Will it send ARP on fast ethernet"
If you mean the router and IP, yes.
04-30-2009 03:51 AM
it will not send arp on serail and send arp on fast ethernet WHhy???
04-30-2009 04:25 AM
04-30-2009 04:36 AM
Thanks josephdoherty
04-30-2009 04:51 AM
josephdoherty,
For fast ethernet...
suppose PC A is communicating(copying or transfering a file) with PC B vai Router A and router B... will router A send ARP for each packet??
04-30-2009 04:56 AM
