HWIC-1CE1T1 problem
Apr 27th, 2009
Hi all,
I try to set up a HWIC-1CE1T1 on a 2811 router, with IOS c2800nm-ipbase-mz.124-11.XW10.bin.
The controller seems to be OK, but as i connected it to the PRI :
- it stays down
- i have a message saying that "the remote received an alarm".
Did someone have the controlers parameters to set up in France ?
For now, i just have :
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31
I tried to add a clock source with the same result.
If i put another router (not a Cisco), the PRI goes up without any problem.
Thanks for your help.
paolo bevilacqua Mon, 04/27/2009 - 08:26
  • Hall of Fame,
    Founding Member
May be framing is CRC4. Take "show controllers E1" is both cases. There are no other parameters to set.
vibrisnet Tue, 04/28/2009 - 07:18
I tried both CRC4 and NO-CRC4, with the same result.
