Policy Based Routing with Deny
Apr 27th, 2009
Hi All,
We have a Cat-3550 with a route-map for a SVI (VLAN 1) to redirect the traffic. Everything is fine except for the fact the traffic to the other VLANs are also routed the same way with additional hop. I would like to exclude this using a deny statement but for some reason that doesnt seem to work. Please find the config details below:
interface Vlan1
ip address 10.18.1.2 255.255.255.0
ip directed-broadcast
ip policy route-map server
no ip mroute-cache
end
route-map server permit 10
match ip address servers
set ip next-hop 10.18.122.6
ip access-list extended servers
permit ip 10.18.1.0 0.0.0.255 any
New config (which doesnt work)
route-map newserver deny 10
match ip address 199
route-map newserver permit 20
access-list 199 permit ip 10.18.1.0 0.0.0.255 10.18.2.0 0.0.0.255
access-list 199 permit ip 10.18.1.0 0.0.0.255 10.18.3.0 0.0.0.255
access-list 199 permit ip 10.18.1.0 0.0.0.255 10.18.4.0 0.0.0.255
access-list 199 permit ip 10.18.1.0 0.0.0.255 10.18.5.0 0.0.0.255
What am i missing here. Thanks in advance,
Cheers
subra
Overall Rating: 5 (1 ratings)
thotsaphon Mon, 04/27/2009 - 09:23
  • Gold, 750 points or more
Subra,
Your configuration looks good to me. You want to deny switching between Vlans to let them go using the normal routing table.
You may use a "debup ip policy" command to see what's going on.
Well, in case it really doesn't work. You may think about other ways.
route-map newserver permit 10
match ip address only-for-server
ip access-list extended only-for-server
deny ip 10.18.1.0 0.0.0.255 10.18.2.0 0.0.0.255
deny ip 10.18.1.0 0.0.0.255 10.18.3.0 0.0.0.255
deny ip 10.18.1.0 0.0.0.255 10.18.4.0 0.0.0.255
deny ip 10.18.1.0 0.0.0.255 10.18.5.0 0.0.0.255
HTH,
Toshi
subra4u Mon, 04/27/2009 - 09:52
Cheers mate. It works.................
thotsaphon Mon, 04/27/2009 - 09:27
Bret,
Are you really thinking about that way? If so, 5P! for you anyway! heheheh..
Toshi
thotsaphon Mon, 04/27/2009 - 11:34
bret,
Maybe less than one minute! (grin)
Good job,Man
Toshi
