Firewall and OSPF - Passive interfaces??
Apr 27th, 2009
I have a pair of ASA5550 with OSPF enabled on the outside interfaces with our internet routers. Firewalls get the candidate default route from the internet routers.
Anyway, when I do a "sh ospf interface" all interfaces are listed under area0..it should be only the outside interface.
Is there a passive interface command just like for routers??
Jon Marshall Mon, 04/27/2009 - 10:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Under your router ospf configuration what have you used as the "network x.x.x.x area 0"
ie. does x.x.x.x also cover you other interfaces ?
Jon
opers13 Mon, 04/27/2009 - 14:36
ha..that's it! I have the subnet for the inside network in there...
Thanks Jon
