Unity 4.2
Answered Question
Apr 27th, 2009
I perform a New Installation of Unity with exchange 2003, and CUCM 6.1.2 and the integration was with sip, all it's ok.
I have a problem, when an subscriber call to the unity, he listen the login promt, but whe any other number (Internal or External), try to reach this extension, the unity don't play the subscriber greeting, it play the call handler greeting, and I can dial the extension again and the unity play the greeting of the subscriber. when I change the call handler, when the subscriber try to reach yours messages from your extension, the unity play the subscriber greeting, invite to leave a message.
I need help to fix up this issue.
Correct Answer by Jaime Valencia about 8 years 3 days ago
check the routing rules for FW calls, make sure they send you to the users greeting
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 04/27/2009 - 11:09
  • Cisco Employee,
  • Hall of Fame,
    2011
java
sjvitales Mon, 04/27/2009 - 13:49
Hi, I perform the integration with SIP, and when I try to reach and subscriber mail box (FW), to leave an VM, the system ever play the Welcome greeting, invite to dial an extension or wait for the operator,
I change the Call-Route Parameters, and nothing happend.
Regards.
sjvitales Mon, 04/27/2009 - 14:18
Hi again,
The issue was solved, the trouble was that the option "Redirecting Diversion Header Delivery - Outbound", i miss checked, and the correct information of the CUCM was not sent to the unity server.
